Home AMX Control Products
Audio Out from 8400
Hi. How can I use the mic audio from the panel?
Where Can I found documentation about input/output audio from the panel?
Thanks a lot
Alex
  • AMXJeffAMXJeff Posts: 450
    The MVP8400 does not have a mic, just speakers. The MVP8400i does have a mic, and it is dedicated for VOIP. The wired touch panels, do have a mic that you can tie to any mixer using the AV breakout box. Cat5 cable between the breakout box and the touch panel.
    Hope this helps...
    Thanks a lot
    Alex
    Hope this helps...
    Sure? If I look here
    http://www.amx.com/products/MVP-8400.asp
    it says:
    Built-in Speakers (2) and microphone
    How can I use it?
    Thank's a lot
    Alex
    If there is actually a mic on the 8400, it was for future use.
    it says:
    How can I use it?
    Thank's a lot
    Alex
  • 8400i audio
    If I use 8400i , can I use the mic audio? I need to send the audio to an external device
    Thanks a lot
    Alex
    Thanks a lot
    Alex
    I beleive it is only for the VOIP/Intercom function, not for external use.
  • How can I do? I need a wireless panel with the feature of mic line. Does exist a panel with this feature?
    thanks and sorry for my English.....
    I beleive, at this time, you're out of luck. It has been a wish of many of us for some time now.
    You might put it in as a feature request with tech support.
  • Intercom with another AMX Panel is possible with MVP8400. You need a software for activate the audio-channel to the other panel's. We setup a door intercom with a CV7 and a MVP8400. But the sound is pretty bad....
    If you need this Code please write again. Im not in the company tonight....
  • Thanks thomas. Please, send me the code at the email beta @ blulaboratori . org ( without space)
    Thank's a lot.
    alex
  • Here is a note from the NXT-CV7 manual.
