Audio Out from 8400
eddymouse
Hi. How can I use the mic audio from the panel?
Where Can I found documentation about input/output audio from the panel?
Thanks a lot
Alex
Thanks a lot
Alex
Hope this helps...
Sure? If I look here
http://www.amx.com/products/MVP-8400.asp
it says:
Built-in Speakers (2) and microphone
How can I use it?
Thank's a lot
Alex
If I use 8400i , can I use the mic audio? I need to send the audio to an external device
Thanks a lot
Alex
I beleive it is only for the VOIP/Intercom function, not for external use.
thanks and sorry for my English.....
You might put it in as a feature request with tech support.
If you need this Code please write again. Im not in the company tonight....
Thank's a lot.
alex
