MET-6N Firmware v.11.2 bug heads up and workaround
in AMX Hardware
I reported a bug today regarding the MET-6N keypad firmware v1.11.2. The keypad does not release the channels or level on reboot which causes a problem with feedback. AMX has confirmed the bug and said that it will be fixed in a future firmware release.
I don?t know if the MET-7 or MET-13 exhibit the same problems but I imagine they might since they use the same firmware.
The workaround that I?m using is to pulse all the channels and do a level change when the keypad comes ONLINE:
Hope this saves some troubleshooting time for those that are using the keypads
DATA_EVENT[dvKeypad] { //MET-6N ONLINE: { //@BRT-<on brightness (0-32)>,<off brightness (0-32)> SEND_COMMAND DATA.DEVICE,'@BRT-32,0' //?@WBRT-<on brightness (0-32)>,<off brightness (0-32)>? SEND_COMMAND DATA.DEVICE,'@WBRT-32,0' PULSE[DATA.DEVICE,1] PULSE[DATA.DEVICE,2] PULSE[DATA.DEVICE,3] PULSE[DATA.DEVICE,4] PULSE[DATA.DEVICE,5] PULSE[DATA.DEVICE,6] PULSE[DATA.DEVICE,11] SEND_LEVEL DATA.DEVICE,1,255 SEND_LEVEL DATA.DEVICE,1,0 } }
Thanks for the heads up! We just got these in (all three of them), and I'll be programming these soon. I like the "future" update line . . . I just don't understand why that if it's a known bug they don't release a fix for it immediately.
Ahh - I misread. I thought you said that AMX knew about it already. Whoops!
And I also agree with vining's statement. At the very least, they should send out an email to everyone that's bought one. I mean - don't they do that with baby seats?
I'll give them some time though.
http://www.amx.com/techcenter/firmware.asp?Category=Keypads#Metreau%20Keypad%20(AxLink)%20Firmware
i just recently got 3 of these MET-6N that i need to program. how do i update my firmware with this *.tsk file?
Tools > Firmware Transfers > Send to Axcess Device
That is correct.
