Problem with NI-3100
in AMX Hardware
Hello,
When I put the power, the leds: status, output and input starts blinking ... what's wrong?
Thanks!
Thanks!
Any idea?
Thanks!
If it was out of the box, the problem is probably that the network card is set to DHCP and it's looking for an address from a network. The thing will normally take about 30-45 seconds to reboot upon power up. However, if it's looking for an IP address from a DHCP server, it could hang for considerably longer. While it's looking, it will not respond to Netlinx Diagnostics connected even via RS-232. If the LED is flashing pretty quickly (2-3 per second) it's just saying, that it didn't find a network.
Wait until it's booted up and go in with Diagnostics and change the network settings to static and give it an address. It'll boot up just fine.
