Axlink Wiring
in AMX Hardware
Transmission medium = Shielded pseudo differential twisted pair
The above is a direct quote from the Axlink Spec sheet.
I am not 100% sure as to what this is meaning. I was under the impression that running 18/4 stranded was the recommended wire.
What is the best wire or what are you guys using?
We use West Penn 77350 for our rough-in work.
Liberty wire company has cable made specifically for AxLink. It's 2 conductor inside a shield w/ drain wire. then 2 conductor outside that sheild for power. Total of 4 conductors plus a shield.
We also commonly use Lutron 'Green' wire for Axlink which is practically the exact same thing.
