Vista telnet
Does anyone have any experience using telnet with Windows Vista? I "installed" it without a problem, and can get the telnet window up, but I can't seem to use any of the commands I'm familiar with. I mean including "ping", and "telnet xxx.xxx.xxx.xxx"....
And to think I just said yesterday "I haven't had an issues with Vista."....
http://www.tech-recipes.com/rx/1793/vista_install_telnet_client
Not sure if this is the problem?
"ping" and "telnet" are executables that you ran from the command prompt in whatever earlier version of windows you used.
Vista does not have a telnet program installed, you need to install one, it may or may not be accessible from the command prompt (it may or may not be in your user's path is the actual question).
Try running cmd.exe from the start menu, then you can ping just fine from vista.
Edit:
BTW, there is no relationship between telnet and ping. Ping is a network tool, just like telnet. Ping tests icmp type 8, echo, which will tell you if there is even a host at that ip address, but it will not tell you at all whether telnet is accessible at that host. Telnet is TCP port 23.
