sleep button
I have a request to add a sleep button to an 8400 in a WDS in a conference room. They want to be able to press a button to sleep the display like the button on the bottom of the wired panels. Is there a code in TP4 or does this need to be done programatically?
thanks
  • I think the right way is to go in TPD4, Menu-> Project Properties->Panel Setup Information and define a command for SLEEP. It can be literally "SLEEP" or wahtever, which will be triggered by using SEND_COMMAND to the TP device.
    Works just fine with MVP5200i.
  • Asking out of curiosity, not as a rebuttal...
    Couldn't the same function be accomplished just by using SEND_COMMAND dvTP, "'SLEEP'", without doing anything in the panel set-up?
  • I guess. I believe the setting there is for receiving the string as feedback when falling asleep on its own.
  • yuriyuri Posts: 861
    true.
    You could copy the button from the setup pages (don't know if there is a sleep button there, but if it is, you can copy it :p )
  • ondrovicondrovic Posts: 217
    Just tried this on a 7500 and it seems to work
    Send_Command dvTP,"'SLEEP'"
    Send_Command dvTP,"'WAKE'"
    That's cool :)
  • Just to through out another option.
    You can also use the loop back port on a button.
    in button properties, under the program tab set the command port to 0 (loop back port) and type
    SLEEP
    for the command output. Now when ever that button is pushed the panel will go to sleep. No extra code required!
