Java SMTP and Email
Has anyone found any email code that works with the netlinx masters? I found one java app that was written to add an email client to j2me devices, but it includes a lot of UI stuff that is unnecessary for use on an AMX processor. I am planning on pulling out the bits I need, but I figured I would check to see if anyone has found anything first (maybe even something included with Cafe Duet).
The main thing that I need is the ability to send an email with an attachment (or a few attachments).
The other thing I would be interested in is receiving emails, but this is not an immediate need.
try this and see how it goes.
Note: I reloaded the zip file as the old one contained an error. This version is corrected. 12/02/08 - 8:40 Eastern
After seeing how easy it was to get a functional zip program in duet, I am getting spoiled
While at Prog III part deux, I heard the Siren song of Duet. While it offered nothing that spectacular for all things AMX, it did open a whole bunch of possibilities beyond that made me want to come up the the 1.2 grand to start programming in JAVA.
alas and anon...
e
PROGRAM_NAME='i!-EmailOut' (*********************************************************************) (* AMX Corporation *) (* Copyright (c) 2000 - 2002 AMX Corporation. All rights reserved. *) (*********************************************************************) (* please refer to EULA.TXT for software license agreement *) (*********************************************************************) (* *) (* i!-Email (1.1.8) *) (* *) (*********************************************************************) PROGRAM_NAME='i!-EmailOut' (***********************************************************) (*{{PS_SOURCE_INFO(PROGRAM STATS) *) (***********************************************************) (* FILE CREATED ON: 08/03/2001 AT: 10:42:21 *) (***********************************************************) (* FILE_LAST_MODIFIED_ON: 03/20/2003 AT: 23:13:17 *) (***********************************************************) (* ORPHAN_FILE_PLATFORM: 1 *) (***********************************************************) (*!!FILE REVISION: Rev 0 *) (* REVISION DATE: 12/10/2002 *) (* *) (* COMMENTS: *) (* *) (***********************************************************)Oops, I think I did that by accident. I had to take out a couple lines of code that I put in that are custom to what I do and would hurt normal SMTP operations. Sorry about that.
I reloaded the file above.
Confronting the same issue, what to send emails within Duet. Is that Java code you found still available?
