I Saw this on Ebay!
Since the topic has come up, I decided to start a thread. If it gets used a lot, maybe it will turn into a section.
I just looked up the current listings on Ebay, as I do not have anything listed that is AMX related right now.
**************NOT LISTED BY ME*******************
Anyone looking for an inexpensive way to test TP files, check out Item number: 250336480432. A TPI/4 with a buy it now of $379.00. From what I understand, you can send most of the touch panel files to this unit. Just VNC into the unit and check out your touch panel functionality... or connect it to a monitor and use a mouse
(I think)
In both instances the sellers were fantastic and took the merchandise back.
We also have a couple 8400s but I don't own them personally so I don't know when they will be listed.
You don't need the input cards to use it as a touch panel engine only (with no video). The input cards allow you to show video on the TP (VGA out in this case, or VNC as mentioned).
- Chip
