Home AMX Design Tools
Animation Problem
Hello. I put this thread under Design Tools as I think it is a button property issue with TP4 Design 4. I have a multistate button (29 states) on a MVP8400 panel. The button was created using the animation wizard. The button sits on the splash "start up" page and is supposed to be animated. The button rotates a company logo as expected with the button view tool. It is not animated when using the G4 panel builder nor when loaded onto the actual touch panel. Am I missing something in the properties that the wizard did not address? Any ideas?
Eric
    ereed wrote: »
    Eric
    How do you have the feedback properties set?
  • jjamesjjames Posts: 2,908
    Check, check, 1, 2
    Verify your properties if you want it rotating without any code.
  • ereedereed Posts: 11
    Hey Eric & Jeremiah,
    Thanks for the assistance. The auto repeat was set to yes, but I did not have the feedback to "always on".
    Eric
    One more idea.... set the feedback to channel. In your processor, set the channel to turn on when the panel is online (or turn it on at start up). This way, the logo will only spin if the panel is online and conceivably ready for use.
  • jjames wrote: »
    Verify your properties...
    Ooooo, nice graphic.
    --John
    --John
    Well thank you! The joys of working with Adobe Fireworks! ;)
