Post revision
I'm not sure if this is a new feature, or a feature I just finally got to see.
I just edited a post (grammatical error) and after I fixed it, it said the usual at the bottom of my post: "edited by jjames at 9:46" or something to the likes. However - it was a hyperlink. I clicked on it and was able to choose which version I wanted (old or active) and also could compare the two.
Is this a new feature? If so - thanks! I like the idea that I can "undo" what I just did without having to remember what I did.
Or is the hyperlink only for the poster?
The only reason I tend to edit is to correct spelling or grammar errors. I tend to not edit my posts when angry. I have a little rule with myself on that. If my hands are shaking when I'm typing, I'm too angry to post. So, I don't post at all if my hands are shaking.
I would hope that the feature doesn't allow for going back to previous edits. I believe we should all be gracious enough to allow for people to take back what they say.
Maybe there's a need for an email notifications delay or better yet don't post anything you'll later regret. Although that's hard sometimes.
Regardless the outcome, simply typing the reply helps me get it out of my system so I can move on and return to work. To this point, I haven't accidentally clicked the submit button, but I 'm sure it will happen.... that's when editing is nice
So my personal rules are as follows:
1) Never post when angry or upset
2) Never post anything you wouldn't feel free to say to someone's face
3) Vet responses carefully (this is the one I'm most likely to break; my prime forum times are first thing in the morning when I am still fuzzy, and when I am taking a coding break ... when I am fuzzy in a different way; so I'm not usually at the top of my game when on the forums, and I really have to work to be careful)
4) If any of the above rules are broken, suck it up and take whatever repercussions follow. If a correction is needed, or an apology, put it in a separate post. In the odd case where a minor correction is needed, then I might edit the original, but that is rare, and if it's anything more than a spelling correction, I'll note at the bottom what I changed.
I have learned (the hard way) that this doesn't always hold true. The problem is that occasionally something is said with a certain connotation that does not translate in the forms. When were are speaking to people, we use different tones and inflections to indicate our feelings. When we are speaking in person, we also have the added benefit of reading body language. The lack of this information can lead to misinterpretation. Sarcasm being missed, or sarcasm being interpreted when not intended are common. (which is why I try to temper my use of sarcasm in the forums.... I said try, not succeed
I suppose that is the other problem with forum posting. When communicating in person, responses are immediate and if there is a misunderstanding (most of the time) it can be cleared up immediately. In the forums, it may be a few hours or days before a poster can clarify a statement and this can lead to wild speculation by other posters as to the original intent. In the least, the person that questions the intent is left to stew about the intent and possibly blow it into proportions that are not needed.
P.S.
I am acknowledging right now that I am not a psych[anything]ist, and I have not researched these ideas. I am speaking purely from personal experience derived from this and other forums.
I've long lobbied for some international emoticon to be made for sarcasm. I suppose the English wish we Americans could understand the 'ironic' emoticon too. alas and anon...
Let's start an international convention, today!
--John
I'm glad! This new "feature" was going to significantly impact my post count
Here's an old one of yours Dan: http://www.amxforums.com/showpost.php?p=12831&postcount=1. I couldn't access your edit either. Does yours show up for you?
--John
