Feedback of Rotel RSP-1098
HI All,
Does anyone know how to pharse the Rotel RSP-1098 Feedback?
the protocol is not so clear and, now a days any AMX module is ready for that product.
The main difficulty is when the processor respond me with the standard protocol, it put's in che char section all the information about Volume or about what sourche or what kind of sorrund I've selected.
But it send to me that messages without telling me what they are refer.
Does anyone has got an Idea for pharsing the Rotel RSP-1098 Feedback?
Thanks a Lot
Kman88
Thanks a Lot
Kman88
Now, why Rotel didn't think to use some kind of key word like 'Volume' for a volume change is beyond me.
I'm not sure if I still have to code, but essentially there's 2-3 bitwise characters, display text, then 2-3 more bitwise characters. Pull out the middle display characters and right_string the last 3 characters. If you find MIN volume is 0, MAX volume is 100, anything else do an ATOI and you get the volume.
You will have to compare the last message to the current message to make sure the input (whatever it is) is the same and it's not scrolling a message across.
FWIW, they fixed it in anything newer. There's two display lines. First has the bitwise info, input, and the VOL XXX. Second has any surround info and scrolling text.
Kevin D.
The question is why rotel didn't think about some standard messages that AMX can pharse well?
Bye Guys
Kman88
I suspect the protocol was designed for a PC application, and AMX or C were not on their minds at all.
DATA_EVENT[dvRotel] { STRING: { IF(FIND_STRING(BUFFERROTEL,'VOL',1)) { REMOVE_STRING(BUFFERROTEL,'VOL',1) ROTELVOLUME=MID_STRING(BUFFERROTEL,2,3) } ELSE { CLEAR_BUFFER bufferrotel } } }
