Web Control Help
Hello,
Could someone tell me the best/most reliable way to do Basic AMX Web Control. I am using NI-4100 controllers if that helps
1) use the web panel access on a Modero panel. (requires a Modero panel)
2) use the G3 web panel built into the software side of the Netlinx controller. Doesn't require hardware but is not very reliable and has been flaky at best. I've found you can only rely upon 1 page in the panel. I only use it for very simple things. Like a web HVAC for the client to log into. Also, keep the graphics very simple)
3) write your own and do it from code.
Using even a basic 5" panel seemed more than a bit of a waste. The 435 panels have VNC so they do the job and they're cheap enough to stick one in at the rack.
