DirecTV Responding Issues
I have 5 DirecTV HR21P-200 units - All 232, all of them controlled with the same Module, (I rolled my own based on other peoples examples).
THe control works on all of them. - I can select anything
But I have 2 or them that will not respond. 3 of them will respond to queries (chan number) etc but 2 have no responce at all. I've tested the cables, confirmed pinouts (the TX works) shorted pins 2&3 at the receiver end and I can see the commands I send out comming back at me. It doesn't look like a cable. So it must be the receivers.
Anybody run into this?
Any fixes out there?
Can I call DirecTV tech support - or will they just blow me off?
THere - we're even again
"The USB port on most STBs support hot-plug. That means USB ports will work any time when a
USB-serial adapter is plugged in. Only the HR20 and HR21 USB ports works differently. The USB serial
adapter must be plugged before the STB is booted. If the USB connector is plugged in when the STB is running, it must be reset."
I kind of ran into the problem once (it wouldn't talk from the get-go), so I did a hard power cycle and it worked after that. I didn't know about the HR20s & HR21s needing to be reset. I'm not sure if the red button does the same exact thing as a hard power cycle - worth a try?
Always better and more satisfying than a reset button
Ahh shoot, that's right - you've got the Pro piece. Hmm . . . I hope it didn't have anything to do with an update.
Reboot AMX? Change baud rates? That's weird though, I'd have to lean towards a box issue and not the programming or the processor.
Also, we use the Synaccess NetBooters on all of our projects with the DirecTV boxes and set them to auto ping the boxes. They can perform automatic reboots if the boxes lock up, or if the client needs to hard reboot them from the touch panel.
--John
OK - all the firmware is the same. I rebooted the units that were not responding - still not responding...
THe lake is only 100' away - I'm thinking of taking them for a little swim
