G4 Web control STOP working on 8400
Darkman88
in AMX Hardware
HI Guys,
I've a problem with an 8400 panel, I wold like to control it by remote so I've enagled the G4 Web control functionallity, but after a day I can not connect to the panel anyway, it seems that G4 Web control function stop working, so I send a reboot command to the panel and then the G4 web control start to work for another day....
I thing that is so strange think Have U got any Idea?
Kman88
Kman88
If you do a ortscan of the ip of the panel, the port 5900 isn't open it's like when you disable the G4 web control.
Also, the next release of MVP-8400 firmware will allow you to increase the number of G4 web control users to a max of 3. Coming soon....no, seriously... :-)
but it's still online with the NI-Master, I dont know why, when I reboot the panel, Ican ping it, telnetting and access to G4 functionallity.
The timeout is setted at 15 min, and I have the last firmware.
I use TightVNC
Thanks Kman88
So in how do you solve the problem? do you said to your custumer to remember to reboot the panel whenever he leave home?
I don't have a great solution. If his housekeeping staff is there, he tells them to reboot it (I provided a reboot button on it). If the house is vacant, he calls me and I telnet in and reboot it. It doesn't happen very often, so this has been workable ... I wouldn't want to do it that way if the thing was dropping out more frequently.
I would beleve that is a firmware problem...
I agree. Getting a fix will be the hard part.
Do you think it would be feasible to reboot your panel periodically from code? At 4AM or something, do a quick check to see if the panel is in use, and just send a reboot command if not. I've done that a few times with poorly made devices that locked up regularly.
Dont Know, I think that is hard to know when the panel is in use.
Yes there is not so much people that use AMX panel at 4:00AM but It can happen.
I agree with you, it's a solution but It's not nice to say to coustumers:
"If you see the panel rebooting dont worry, It's Just because G4 function in AMX panel suks..."
I think that he can be a little bit angry with me...
If the panel is in a bedroom, however, all bets are off. The thing waking up and rebooting may drive them crazy.
I have run some tests and cannot get G4WC to fail. The only times I can get it not respond are when I try to connect within like 2 seconds of a disconnect. But that clears up after about 5 seconds. I have made 40 or 50 connects in a row. I have done 20+ connects and then let it time out, all in a row.
What I cannot simulate is the environment or network at the locations in question, or the exact timing between the connections at those sites. There will be a new 8400 firmware release coming soon, it would be an interesting test to see if this issue goes away.
