Axis Camera 213PTZ
Axis_213PTZ.zip Module for the Axis Communications camera model 213 which is a PTZ type camera. An IP camera which uses HTTP type communications protocol. Supports as many cameras as instances created, 4 bargraphs for Zoom, Focus, Pan & Tilt. Buttons for the same plus IR, IR Filter, Iris, etc. Preset page for up to 18 presets that overlays the camera image. Presets are set and labeled on the TP and written to the camera so they match if you log in directly via PC.
Should work for any model Axis PTZ Camera although not tested.
The TPD4 file was missing the keyboard for the text entry.
Thanks a ton for sharing this!
Jeff B
