Problem communicating via RS-232 with Russound MCA-C5
Hello,
I am trying to communicate with a Russound MCA-C5 using RS-232, however there appears to be a problem with my code since I am getting no response from the system at all. Here is my code:
DATA_EVENT[dvRussound]
ONLINE:
SEND_COMMAND dvRussound, "'SET BAUD 19200,N,8,1'"
SEND_COMMAND dvRussound, "'HSOFF'" //TURN HARDWARE HARDSHAKING OFF
BUTTON_EVENT[dvTP_Russound, 1]
PUSH:
SEND_STRING dvRussound, "$F0, $00, $00, $7F, $00, $00, $70, $05, $02, $02, $00, $00, $F1, $23, $00, $01, $00, $00, $00, $01, $12, $F7"
According to the Russound serial protocol that string should turn on all the zones for controller id 00, however nothing is turn on. Does anyone have any experience working with Russound?. I would really appreciate some help.
Thank you.
Regards,
-Oscar
ONLINE:
PUSH:
Thank you.
Regards,
-Oscar
Code looks ok, are you sure you have the protocol correct? Not sure if this is the older protocol but a quick look at the 1.00.4 protocol shows All Zones On as:
$F0,$7E,$00,$7F,$00,$00,$71,$05,$02,$02,$00,$00,$F1,$22,$00,$01,$00,$00,$00,$01,$10,$F7
Also, I would try sending the command using Netlinx Diagnostics.
--John
Hello John,
Thank you so much for your help, well according to the manual I have all zones up should be that code, but I will double check on that and the cable wiring. Additionally I don't suppose the spaces between the hex values is a problem?. Is "$F0,$7E.." the same as "$F0, $7E.."?.
-Oscar
Just finished working on one of these myself, Ensure your baud settings are correct in the system software for the unit as well, i believe theres an option to change it from a certain mode to another control method, i actually got mine working with 115200 baud, and just using pins 2,3 & 5 ...
