TP transfer with TP Design vs. Netlinx Studio
Joe Hebert
If you open a TP file with TPD4 there is a (for lack of a better term) compiling process before the file is transferred.
When you transfer that same file with Netlinx Studio it appears to just blast away and transfer the TP file as is.
This leads me to believe that either:
A) The final file loaded into the TP is different when using either method.
Or
2) There is some sort of error checking that takes place when using TPD4 before the file is sent.
Or maybe something else but there sure seems to have to be some sort of difference.
Am I better off always transferring with TPD4 instead of Netlinx Studio?
If not, what?s all the extra work that TPD4 does that?s not getting done with Netlinx Studio?
Or
You will see a difference in send times in TPD4 when you send a cv7 file to a cv7 vs a cv10 as it goes throught the conversion without really converting process.
Since Studio can't transfer a file while it is open in TPD4, because it is locked, it is actually transferring the "real" TP file, not a temporary copy.
Thanks for the insight.
Since TPD4 goes through its compiling process I would think it?s possible that a file transferred with TPD4 may not always be equal to the file that is transferred with Netlinx Studio.
I suppose it?s one of those things I shouldn?t be wasting my time thinking about.
