UDM-0808 doesn't come online in TCP/IP listen mode
Hello,
I have a problem with a UDM-0808.
It doesn't come online in an AMX Netlinx system when i use the Master connection mode "TCP/IP listen".
However it works fine if i use the Master connection mode "TCP/IP URL"
I need however this device to work using the listen mode because i need 2 seperate Netlinx masters to connect to it
see
http://www.amxforums.com/showthread.php?6816-One-touchpanel-two-masters....how-to-dynamically-connect-to-the-touchpanel
for more information why i need this.
see
Thanks for your reply.
But the matter seems to be solved by a new firmware for the UDM-0808.
I think you're confusing "listen" with "auto." In "auto" the device needs to see a UDP broadcast. Once it hears the broadcast, the device attempts a TCP connection to the master. "Listen" does not; the device simply listens for a TCP connection originated by a Master via a Master URL list entry.
Chuck
Ok but what about touch panels that aren't in the M2M URL list running in "listen" mode. Do these TPs run a simple server when in listen mode on a particular port and do the masters just run through the possible IP addresses for their subnet attempting to initiate a connection on this port? If something accepts they exchange greeting cards, if not it move to the next IP address and knock on their door?
How does this work?
I have used this method to make a backup system for the master.
All devices (touchpanels and udm0808's) are in listen mode and connected to Master A.
Master A sends watchdog messages to Master B using MasterToMaster communication.
When Master B doesn't recieve watchdog messages anymore, Master A must be down. Then Master B dynamically load's it's URL list with all the IP adresses for the touchpanels and UDM0808's in the system and takes over control.
When Master A comes online again, and sends a watchdog message to Master B, Master B dynamically deletes all the IP's from its list so Master A can take back control over everything.
I have used this method to make a system (containing 4 UDM0808's and 10 touchpanels) failsave in case of a problem with a Ni Master. When Master A goes offline, Master B takes over within 1,5 minutes.
