Monitoring presentation PC status with RMS
Is there any support for monitoring the status of a presentation PC with RMS ?
Perhaps some sort of agent that can be installed on the presentation PC to communicate with the Netlinx controller either over Ethernet or RS-232, which can then be used to provide status monitoring in RMS. Integration with vPro ?
Dave
Dave
With i!-PCLinkWeb you can monitor several metrics:
- PC Date/Time
- PC Volume Level
- PC Mute State
- PC Resolution
- PC Name
- PC IP Address
- PC logged on user
The you could also use ConnectLinx to register remote function in RMS such as
- LOGOFF
- REBOOT
- OPEN WEB PAGES
- SET VOLUME
- SET MUTE
See the Programming i!-PCLink/Web :: Commands section of the help file:
http://amx.com//techdocs/0332555.pdf
With i!-PCLinkPowerpoint you could monitor:
- OperatingSystem Name
- Power Point Version
- Current Presentation Name
- Current Slide Title
- Total Slides Count
- Current Slide Index
See the Programming i!-PCLink/PowerPoint :: Send_Commands section of the help file:
http://amx.com//techdocs/i!-PCLinkPowerPoint.Instruction%20Manual.pdf
I am not aware if anyone has integrated these softwares before with RMS, so your mileage may vary, but it should be possible.
