Lutron HomeWorks QS vs. Intercative differences
RicardoSiqueira
I wonder if the AMX module that works with Homeworks Interactive will also work with the HomeWorks QS. Have Lutron changed the protocol? Are the strings any different? I've been using the 'HWInteractive.tko' non duet with my own UI for years and the systems have been as reliable as it gets. Any ideas or suggestions? Any sample code from a QS system? Thanks.
Ricardo
Ricardo
On the bright side the QS provides an integration xml file that could be used by pulling it from the P6 processor to config the AMX module. No hand entry of dimmers names, scene names, rooms, etc. So far the protocol isn't 100% so in theory is should be an improvement. We'll see!
