Home MODPEDIA - The Public Repository of Modules for Everyone
Promethean PRM-35/EST-P1
Hi,
Any one successfully controlled a PRM-35/EST-P1 projektor from Promethean?
They have used to have have Sanyo projs. inside, but they seem to have changed OEM provider...
The codes are now:
Power ON:~PN<CR>
Power OFF:~PF<CR>
Input RGB:~SR<CR>
And so on...
I haven't managed to get it up and running yet...
Anyone familiar with either the model or have seen theese codes before??
Kenneth
    kennethk wrote: »
    Hi,
    The codes are now:
    Power ON:~PN<CR>
    Power OFF:~PF<CR>
    Input RGB:~SR<CR>
    And so on...
    Kenneth
    Those codes are pretty straight-forward. Post your code. Perhaps there's a problem there.
  • Thanks, but the problem is either faulty port on the projector,
    or this document lies(attached).
    Actually the document is only "named" PRM-35/EST-P1, so i actually don`t know wich model it is intended for.
    Anyway.
    Tried the codes out on a EST model(which should use the same protocol as the PRM-35), and it worked fine.
    So the PRM-35, wich is out with the customer needs to be swaped(or i need to find the correct codes...)...?
    Kenneth
  • Did you try firing Sanyo cmd at it??
  • Yes.
    Didn't work
    Kenneth
