biamp audia
i have this biamp audia and need to do a program. i have 8 input and 3 output.
i am done doing my program but i miss some important code but hard to create logic.
1st the volume level in biamp didnt match in the volume bar of my Touch panel.
2nd if i select input 1 going to output 1, then again select input 2 going to same output 1. i want to mute the crosspoint of the 1st selection i made so the sound will not coincide in the latest selection i made. this is the sample of my code
BUTTON_EVENT [dvTP,11] // DJ 1 Ground
PUSH:
[dvTP,11] = ![dvTP,11]
IF (![dvTP,11])
SEND_STRING dvbiamp, "'SET 1 MMMUTEXP 23 7 1 0',$0A"
nSel_Ground = 11
IF ([dvTP,11])
SEND_STRING dvbiamp, "'SET 1 MMMUTEXP 23 7 1 1',$0A"
BUTTON_EVENT [dvTP,12] // DJ 1 1st Flr
PUSH:
[dvTP,12] = ![dvTP,12]
IF (![dvTP,12])
SEND_STRING dvbiamp, "'SET 1 MMMUTEXP 23 7 2 0',$0A"
nSel_1st = 12
IF ([dvTP,12])
SEND_STRING dvbiamp, "'SET 1 MMMUTEXP 23 7 2 1',$0A"
BUTTON_EVENT [dvTP,13] // DJ 1 Outside.
PUSH:
[dvTP,13] = ![dvTP,13]
IF (![dvTP,13])
SEND_STRING dvbiamp, "'SET 1 MMMUTEXP 23 7 3 0',$0A"
nSel_Outside = 13
IF ([dvTP,13])
SEND_STRING dvbiamp, "'SET 1 MMMUTEXP 23 7 3 1',$0A"
// Volume UP & Down
BUTTON_EVENT [dvTP,14]
BUTTON_EVENT [dvTP,16]
PUSH:
SWITCH (BUTTON.INPUT.CHANNEL)
CASE 14:
IF (sVolLevel1<nVolMax1-nVolChange1)
SEND_STRING dvbiamp, "'INC 1 FDRLVL 18 7 1',$0A"
sVolLevel1 = sVolLevel1+nVolChange1
ELSE
sVolLevel1 = nVolMax1
CASE 16:
IF (sVolLevel1>nVolMin1+nVolChange1)
SEND_STRING dvbiamp, "'DEC 1 FDRLVL 18 7 1',$0A"
sVolLevel1 = sVolLevel1-nVolChange1
ELSE
sVolLevel1 = nVolMin1
HOLD [1,REPEAT]:
CASE 14:
ELSE
CASE 16:
ELSE
//Bar Level
LEVEL_EVENT[dvTP,1]
SEND_LEVEL dvTP,1,((sVolLevel1-nVolMin1) *255/(nVolMax1-nVolMin1))
//Mute
BUTTON_EVENT [dvTP,15]
PUSH:
[dvTP,15] = ![dvTP,15]
IF (![dvTP,15])
SEND_STRING dvbiamp, "'SET 1 FDRMUTE 18 7 0',$0A"
IF ([dvTP,15])
SEND_STRING dvbiamp, "'SET 1 FDRMUTE 18 7 1',$0A"
(**********************DJ 1st Flr.**************************************)
BUTTON_EVENT [dvTP,17] // DJ 2 Ground
PUSH:
[dvTP,17] = ![dvTP,17]
IF (![dvTP,17])
SEND_STRING dvbiamp, "'SET 1 MMMUTEXP 23 8 1 0',$0A"
nSel_Ground = 17
IF ([dvTP,17])
SEND_STRING dvbiamp, "'SET 1 MMMUTEXP 23 8 1 1',$0A"
BUTTON_EVENT [dvTP,18] // DJ 2 1st Flr.
PUSH:
[dvTP,18] = ![dvTP,18]
IF (![dvTP,18])
SEND_STRING dvbiamp, "'SET 1 MMMUTEXP 23 8 2 0',$0A"
nSel_1st = 18
IF ([dvTP,18])
SEND_STRING dvbiamp, "'SET 1 MMMUTEXP 23 8 2 1',$0A"
BUTTON_EVENT [dvTP,19] // DJ 2 Outside.
PUSH:
[dvTP,19] = ![dvTP,19]
IF (![dvTP,19])
SEND_STRING dvbiamp, "'SET 1 MMMUTEXP 23 8 3 0',$0A"
nSel_Outside = 19
IF ([dvTP,19])
SEND_STRING dvbiamp, "'SET 1 MMMUTEXP 23 8 3 1',$0A"
// Volume UP & Down
BUTTON_EVENT [dvTP,20]
BUTTON_EVENT [dvTP,22]
PUSH:
CASE 20:
IF (sVolLevel2<nVolMax2-nVolChange2)
SEND_STRING dvbiamp, "'INC 1 FDRLVL 18 8 1',$0A"
sVolLevel2 = sVolLevel2+nVolChange2
ELSE
sVolLevel2 = nVolMax2
CASE 22:
IF (sVolLevel2>nVolMin2+nVolChange2)
SEND_STRING dvbiamp, "'DEC 1 FDRLVL 18 8 1',$0A"
sVolLevel2 = sVolLevel2-nVolChange2
ELSE
sVolLevel2 = nVolMin2
HOLD [1,REPEAT]:
CASE 20:
ELSE
CASE 22:
ELSE
//Bar Level
LEVEL_EVENT[dvTP,2]
SEND_LEVEL dvTP,2,((sVolLevel2-nVolMin2) *255/(nVolMax2-nVolMin2))
//Mute
BUTTON_EVENT [dvTP,21]
PUSH:
[dvTP,21] = ![dvTP,21]
IF (![dvTP,21])
SEND_STRING dvbiamp, "'SET 1 FDRMUTE 18 8 0',$0A"
IF ([dvTP,21])
SEND_STRING dvbiamp, "'SET 1 FDRMUTE 18 8 1',$0A"
PUSH:
IF (![dvTP,11])
nSel_Ground = 11
IF ([dvTP,11])
PUSH:
IF (![dvTP,12])
nSel_1st = 12
IF ([dvTP,12])
PUSH:
IF (![dvTP,13])
nSel_Outside = 13
IF ([dvTP,13])
// Volume UP & Down
PUSH:
CASE 14:
ELSE
CASE 16:
ELSE
HOLD [1,REPEAT]:
CASE 14:
ELSE
CASE 16:
ELSE
//Bar Level
LEVEL_EVENT[dvTP,1]
//Mute
PUSH:
IF (![dvTP,15])
IF ([dvTP,15])
PUSH:
IF (![dvTP,17])
nSel_Ground = 17
IF ([dvTP,17])
PUSH:
IF (![dvTP,18])
nSel_1st = 18
IF ([dvTP,18])
PUSH:
IF (![dvTP,19])
nSel_Outside = 19
IF ([dvTP,19])
// Volume UP & Down
PUSH:
CASE 20:
ELSE
CASE 22:
ELSE
HOLD [1,REPEAT]:
CASE 20:
ELSE
CASE 22:
ELSE
//Bar Level
LEVEL_EVENT[dvTP,2]
//Mute
PUSH:
IF (![dvTP,21])
IF ([dvTP,21])
See comment below quoted code segment
Assuming you can edit the audia config file, you are better off putting a router block in front of the matrix mixer block and doing your source selection there, as router blocks only allow one source to be routed to each output at a time. It will do what you want automatically.
I see nothing in your code that will actually trigger this level event to occur. The line you have in this level event should probably be in the push and hold sections of your volume button events somewhere.
Hope that was helpful
-Ryan
Physically? Download from AMX...
In the code? see the "define_module" statement
Its really frustrating now as i can't make it to work. any sample code that you can share for me?
Are you, or do you work for an AMX dealer? If so, this might be an excellent opportunity to take some more training.
Also, may I make a public declaration that Pastebin (http://pastebin.com/) should be used from now on for large chunks of code?
Do pastebin posts expire and get deleted eventually? I couldn't find any answer to that in their faq.
-Ryan
Of course, this is as much a suggestion as are STOP signs, and budgets.
LOL, thanks I needed some humor today
Given that it's just text, if they say never they probably mean it. So they should stay up till they go out of business or get bought out at least.
Are you monitoring responses from the Audia? If not, try creating a buffer (large as some strings get long) and watching what comes back. It will reply with '+OK' as an acknowledgement, or '-ERR' followed by some description of the error if it doesn't like a command.
Also, are you controlling it via serial or IP? If I'm going to be sending alot of strings in a short time, I use a queue regardless of communication method, and wait for a reply before sending the next command.
You have to match your levels on the Audia with the min. and max. of your bargraph on the touchpanel. Your values will vary depending on the levels on the Audia design. There is a table under Help menu of the Audia software that shows what values corresponds to what dB level.
Hope this helps...
So at this command where can i put the GETL command of biamp?
PUSH:
CASE 20:
ELSE
CASE 22:
ELSE
HOLD [1,REPEAT]:
CASE 20:
ELSE
CASE 22:
ELSE
so the level bar of my touch panel sync. in my biamp volume? is my code correct?
