Array of Strings
jabramson
Is it possible to do an array with strings (or characters) in it?
I'd like to reference this by array index
cINPUTNAMES[] = {'INPUT #1', 'INPUT #2', 'INPUT #3', 'INPUT #4', 'INPUT #5', 'INPUT #6', 'INPUT #7', 'INPUT #8', 'INPUT #9', 'INPUT #10', 'INPUT #11', 'INPUT #12', 'INPUT #13', 'INPUT #14', 'INPUT #15', 'INPUT #16', 'INPUT #17', 'INPUT #18', 'INPUT #19', 'INPUT #20', 'INPUT #21', 'INPUT #22', 'INPUT #23', 'INPUT #24', 'INPUT #25', 'INPUT #26', 'INPUT #27', 'INPUT #28', 'INPUT #29', 'INPUT #30', 'INPUT #31', 'INPUT #32' }
A string is an array of chars. What you are declaring is an array of arrays of chars. What I wrote above describes an array of 32 strings and each one contains at most 10 chars.
cINPUTNAMES[2] -> 'INPUT #2'
cINPUTNAMES[2][8] -> '2'
I'm assuming this was an academic example and you are going to be storing more interesting strings than 'INPUT #2' - otherwise you could just use itoa and forgo the array altogether
[] [] won't work
but
[] [3] will
When dealing with 2 or more arrays the last array needs to be defined with a number in the brackets not just the array itself.
