Drives within Max HT-04 servers?
bob
Anyone tried out different drives within Max HT-04 servers? Are the current 1.5 or 2TB SATA drives also possible? Are those on a software or hardware RAID? Anyone tried login into the box and looking around what is running beneath the AMX software? The box is supposed to be plain Linux with some add-ons...
Linux, Fidora Core. I'm not conversant with Linux, but I imagine any drive you can properly mount should work fine.
One other thing, is that the drives have to be "authenticated" when you install them. In other words, once you put them into the server, you have to go into the HT04 menu and go through the "authentication" process. By the wording and the fact that you have to enter a 16-digit key that comes with the new drives I assume that there is something in place to require the use of the $8000 retail AMX drives.
--John
edit: I just telnetted into one of ours and I see that there's a bbu (battery backup unit) monitor so it's a hardware RAID. Peeked at a manual too and the screenshot shows it's a 3Ware RAID controller.
--John
--John
