Referencing device via variable
Currently I have a button event with a line of code like this:
Is it possible to call the device (dvScaler) as a variable (I know it's a device variable, but I'd like to reference it by char)
Note, this does compile, but throws a warning about char to integer, but will not execute properly
SEND_STRING dvScaler, "StringtoSend"
dvScaler = 5001:6:1 CHAR cDeviceName = 'dvScaler' SEND_STRING cDeviceName, "StringtoSend"
What could you possibly gain if you could do this?
That should not compile, in my opinion. You are violating type rules -- twice.
First, you are trying to assign a character variable as if it were an array. Probably what you want to do is:
define_variable
CHAR cDeviceName[] = 'dvScaler'
That will remove the warning that you are seeing, but it will throw another when you get to your send_string because it is expecting a structure of type device and you are giving it an array of type character. I don't know why the compiler doesn't choke and puke at this. I can only assume that there is some allowance for old Axcess code where there was no type device and the compiler was expecting a single byte integer.
The moral of this story is that you have to obey typing rules if you are going to get the system to do what you want. send_string and send_command expect an argument of type device so that's what you must give. You can name the variable anything you want, but it must be of type device which is a structure with a device number, port, and system -- all integers.
If you want your send_string to work as written, try this instead:
assuming that "stringtosend" works out to be some string.
It'd just be nice to have access to that while in NetLinx:
In Telnet: In NetLinx:
