MXD-2000XL odd behaviors
I was very excited to work on my first MXD-2000XL series panels. But so far I am having quite a few problems and I am wondering if it is my panel or someone out there is having similar issues. Here are the problems:
1) Panel locks up once in a while. I called AMX tech support and they said if panel is too close to the power supply it gets all kids of interference. A reboot usually fixes it. The curious thing is that panels work good for a while, then it happens again. One lock up is already too many. 3 or 4 in 3 days... These panels are way too sensitive. They need some type of shielding.
2) I was demoing the panel for the first time to the end user and the lock up happened again, then the panel was moving pages by itself and did not allow me to do anything. It also needed a reboot. Got home plug in the panel, it worked for an hour or so then the ghost, moving by itself happened again. Another reboot to fix…
3) Page transitions are slow. It looks like the processing power and graphics engine on these panels are not that strong. iPad 2 running TPControl App is way faster and smoother than the MXD-2000XL.
I still have to order 2 more MXD-2000XL for this project and I am getting very concerned. This project also has (1 )MXD-1000, (5) MXD-700 and (4) iPad 3 running TPControl. Client was left out with a bad taste, specially when comparing the MXD-2000XL to the iPad side by side. Any suggestions or ideas before I call in for a RMA?
Ricardo
Ricardo
Our local rep bought a panoramic panel in to play with ages ago and it locked up while I was playing with the AMX demo pages. Our in house panel and a panel we have deployed to a customer site have yet to exhibit this behaviour.
Our in house panel was exhibiting similar behaviour caused by phantom activations on the touch surface (which would sometimes coincide with the location of buttons). Reboot and it would come good for a while. Firmware was released which was purported to fix the problem but didn't. We RMA'ed the panel and the replacement works fine (but appears to have been glued together by a horse and is missing half of the AMX logo on the front - but that's another story).
3 MXD-1000 panels
1st one out of the box worked okay then video lockups and then the phantom touches (mostly upper left corner?)
then too many lockups.
2nd panel working but video locks up
#3 still in the box.
I've seen frequent lockups/granulation when streaming content to X series panels from a third party encoder. I haven't been able to find an encoding profile that the AMX panel handles in a stable fashion. Have concluded I can't make it work and have moved on to other things.
Are you using an MXA-MP or MXA-MPL to provide video to the panel or are you getting it from another streaming source?
Does the third panel have any of the issues of the first two or is it all good?
Ricardo,
I fixed your post so you can just reuse it. I know we've all needed this kind of thing over the last 10 years or so with a lot of the new stuff...
I tried out this latest firmware on a MXT-1900L and it stopped displaying anything that used the GuiFX LCD font.
Weird
I think we've just run into the same issue at a site.
Got the same problem with our touch panel. Shipped the touch panel in AMX USA for repair. Send it back to UAE and it work for sometime only. Again the problem happen to the touch panel.
maybe the touch panel is near to power supply that's why it gets all kinds of interference.
I should add that the touch panels sit on a desk away from the rack and the power supply so we know interference is not the issue.
