Home AMX Technical Discussion
DENON AVR-2112ci module vs AVR-2113ci module/Unit
Has any one used the amx AVR-2112 module effectively with the newer AVR-2113ci unit? I am receiving strings from the AVR and the module is loaded, but apparently something has changed because the module isn't responding to the unit.
Gene
    Some of the new Denon's are using the Marantz protocol now (as are the latest McIntosh receivers). I'm using a Marantz module on my home receiver, which is a Denon.
  • I apologize the denon is a AVR-2313, just for clarification. I tried loading the Marantz sr-7005, still nothing. I can see strings to and from the receiver but no module function.
    geneavone wrote: »
    Something else is wrong. I have a 2313 at home, and it's running exactly the same module as my SR-5007 in the store demo theater. I looked them up, and the 5007 (and consequently the 2313) use the same protocol as the 7005. Make sure you have that module installed in your code properly; some of those AMX modules can be fussy. I wrote my own just to avoid such issues.
