MVP-9000 Woes
This isn't so much a question as a sharing of information, but I wouldn't mind some feedback if anyone has information I might have missed.
I have sold a grand total of two MVP-900's (to the same customer, though on different properties). Both seem to lock up a lot. One has the latest firmware, but seems to freeze when I load a new panel file. It's pretty random, but if I'm going to have an issue, it's when I load a file. Mostly, it simply freezes on the logo screen after the file load reboot. Often when that happens, the load is corrupt and has to be done over. But it will also randomly lock up afterwards ... just just get the "missed" beep (which is how I set my panels up, double beep on a miss, and no sound on a hit). The screen becomes completely unresponsive. In both cases though, I have to reboot it again with the reset button. It's to the point where every time I load a panel file for any minor touch up or addition, I reboot it for good measure afterwards, even though it reboots on load anyway.
The other also exhibits this behavior, but adds to it random lockups no matter what. It is *not* on the latest firmware, but it won't update either. Any attempt to update the firmware fails, even via USB stick. that one is currently at AMX for repair, but I suspect it's going to come back acting like the first.
I've called this into tech support, and got the usual, "we haven't heard of such a problem," but we all know how much that is worth. My hunch is it's a memory issue of some sort, but I'm open to suggestions where else to look. Of course, this is one of those customers that flips out at the tiniest thing that goes wrong, and I grow weary of the pained e-mails that way, "can't you just make my stuff work?"
Other than being way to heavy with real crappy resolution and an often sluggish response to pushes (swipe anticipation delay?) they've actually been pretty reliable thus far. I hope I didn't just jinx myself.
I installed about a dozen of them by now and one of them had similar issue.
It some times failed to show a few popup pages or icon slot images.
They all got back after a reboot.
When new firmware came after a while, I tried firmware update by 3 methods - via NetLinx maste, via micro SD memory, via USB stick plugged in - none of them succeeded.
cheers
