Cannot open Telnet in Netlinx Studio
Hi,
I installed the latest Netlinx Studio on a Windows 8 computer. It seems to work otherwise ok, but the Telnet window cannot be opened. I always get error: Could not open temporary buffer file for the Telnet View. Any suggeestions?
Best regards,
Markku Metsovuori
AV-systems Oy
Best regards,
Markku Metsovuori
AV-systems Oy
If anyone finds a solution, it would be nice to know.
I too use PUTTY and prefer it, so the failure in NLS isn't a big deal. But it makes me worry what else is wrong.
If you right click on a device in the online tree you can select to open a telnet session to the device, that always works so just do that.
Sounds good, but no joy. If I select LAUNCH TELNET IN NLSTUDIO from the right click, it crashes entirely to the desktop. If I select LAUNCH TELNET VIA USER DEFINED PROGRAM, it says CAN'T FIND TELNET.EXE.
You know, after years and years of Telnet in NS not working, kinda working, working but crashing after use, etc... I've just moved on and sworn off it totally.
I use good old Windows CMD Telnet for quickie IP based telnet and PuTTY for everything else. I figure if AMX isn't going to spend the time and resources to fix the darned thing then why waste my time worrying about it. There are some perfectly good options available that don't cost a dime.
My most recent attempts were based on a hope that I could use NLS telnet to reach a slave at a remote site through the NLS connection to the master (which is vaguely implied in the help). There was no VPN and no route to the slave.
It would have been nifty. But Nope, not even where Telnet in NLS works.
Ditto, but I also use Indigo for CLI when working on Cisco switches, Vortexbox and stuff that has to many commands to remember since it allows multiple libraries and variables to be used. Just click a libray entry.
