YouView remote capture
mshunt
Has anyone on here had any success capturing the handset for any of the YouView boxes, I have a TalkTalk branded one I need to control, but while the IRIS I have says it's captured the commands, none appear to work. Just wondering if anyone else has come across the same problem and managed to beat it yet?
I don't seem to be able to attach an .irl file for some reason, so it's here ...
https://dl.dropboxusercontent.com/u/15609314/Humax%20YouView.irl
They are made by Humax but I don't recall if the codes are same as a standard Freeview/sat
Simon
Thanks for sending that through. I however have a Huawei box, which appears to have different codes, at least the humax ones don't work on it. I'll keep trying, perhaps use special mode to try and capture the codes.
Will the USB_UIRT work direct with ir edit, or do you learn the hex codes outside then import them?
It's been said before, but IREdit and the iris are surely top of the pack for upgrades - neither have been touched for years and yet IR files are used constantly.
Simon
Dupe...
sorry to resurrect this thread. i was doing some research online today as i am troubleshooting a current problem i have with the codes for my youview box, and i found this thread. i am learning amx programming and have spent the last few days capturing codes from a variety of devices using an amx iris capture unit and IREdit. everything captured fine and i have got all the kit up and running and more or less working with the code i have written. the only thing that currently doesnt work is the youview box, which is a huawei DN360t, even though everything seemed to capture ok. i've checked pretty much everything - the IR bud, the code, the IR port, the position of the bud on the front of the unit - and still i've had no luck.
can anyone offer any advice or point me in the direction of any hex or working IRL codes?
many thanks
