NXT CV10 Backlight failure
edgelitoc
Had anybody tried to VNC an NXT CV10 with backlight failure and once you connect to the panel you had a black screen, but when you try touching the screen, the button works.
Then I had change my VNC software and everything was working.
Did you use your VNC soft on other device and stuff working ?
Actually on my smartphone (Samsung Note3) I'm making some test with bVNC Free (if this help)
I would try to VNC first on an other device just to be sure all is correct
And then I would try on the break CV10
Thanks for your input, is the backlight on your touch panel still working. The touch panel that I have right now is busted, but you can still hear the button clicks the only thing is the screen is black.
I will try with other VNC software.
Use TIGHTVNC, it always works with AMX and is free. Many others can't cope with the 18-bit color scheme, resulting in black image pages.
If you get control but no image with TIGHT, more than the backlight is to blame.
Kevin D.
No, something IS wrong. It connected and worked once. Then the PANEL rebooted, and now that it's back, it won't accept a connection to Tight.
OK, now it will. FUN. Now it seems ok again.
Maybe I'll go back to the old version.
EDIT A DAY LATER: V. 2.7 is working fine. Looks like a first run issue or a network foo. I made no changes whatsoever to default install settings.
I've had better luck with UltraVNC as well.
I have had 2 NXT-CV10 backlight circuits fail. I think the inverter is to blame rather than the bulb.
Personally, for my Android phone, I use "androidVNC" and "PocketCloud" using the IP address xxx.xxx.xxx.xxx:5900.
Eric
