Big string to widechar string - error
Hi everyone!
I can’t convert big string buffer to widechar string.
The incoming string buffer is (sHTTPBuffer length = 39708) rather big and if I do this
wcHTTPBuffer = WC_DECODE(sHTTPBuffer, WC_FORMAT_UTF8, 1)
OR
wcHTTPBuffer = ch_to_wc(sHTTPBuffer)
and I get loop of this errors in diag
Line 11 (12:51:32):: Ref Error ? Index to large Line=3649
Line 12 (12:51:32):: SetVariable - Error 1 Tk=0x0000
I tried to change the array size
volatile widechar wcHTTPBuffer [50000] or
volatile widechar wcHTTPBuffer [100000] or
volatile widechar wcHTTPBuffer [1000000]
But if incoming’s char buffer length is (sHTTPBuffer length = 4262) – no errors and widechar is converted correctly.
Please advise.
    The function call might have a size limit. Not at my computer to check. You may have to do the buffer in 4Kbyte chunks or on char at a time with a loop.
    Thanks Eric.
    I think you're right.
    I also tried
    sTempBuffer = "sTempBuffer, data.text" in string event, but sTempBuffer stays always 15999 length though it's global var.
    I should try char by char copy ...
    If anyone has such examples I would be very thankfull.
    yeah, using data.text is not going to work due to the size limit. (2K)
    you might try using CREATE_BUFFER. Its size limit is much bigger.
    Actually I do.
    CREATE_BUFFER dvIP_TCP_Client_Http, sHTTPBuffer
    and it grows to 65000 length.
    But unfortunately I can't do this >>
    This doesn't work either if sHTTPBuffer is more than 16000
    for (i=1; i<=length_string(sHTTPBuffer); i=i+9999) {
    wcTemp = ch_to_wc(mid_string(sHTTPBuffer,i,9999))
    wcHTTPBuffer = wc_concat_string(wcHTTPBuffer, wcTemp)
    I see only one way to save widechar buffer
    is to make an array of widechar strings.
    But extracting strings from an array and parsing on the fly can be a challange.
    GregGGregG Posts: 251
    I do my large HTTP downloads to a temp file on the master, then pull out the data to process it after it has all come in.
    GregG,
    Do you use ASCII string or UTF string when parsing ?
    The data stream coming from any modern HTTP 1.1 compliant web server should be US-ASCII so I just handle all the raw data as plain netlinx chars.
    The buffer I use is defined like this:
    Volatile Char cDataBuffer[8192]
    And that is probably twice as large as it would need to be.
    I used the RFC as a protocol document for the internet when I wrote my module:
    https://www.ietf.org/rfc/rfc2616.txt
    I did it!!!
    I changed WC_MAX_STRING_SIZE in UnicodeLib.axi from 16 000 to 160 000 and functions
    like WD_DECODE and CH_TO_WC started to work with large text buffer!
    karageur wrote: »
    I did it!!!
    I'd be very careful tweaking under the hood like that. It could have unforeseen consequences that can bite you later.
