Problem with NI-X100 and NI-X00 after upgrade firmware from 3_60_453 to >
I have a device with on-chip interface IP "Wiznet W3100A". This device connects to NI-3100 (in another project NI-700) over IP standard function IP_CLIENT_OPEN.
Everything worked great, as long as I have not updated from Firmware v3_60_453 to v4_1_404.
After updating Firmware for the controller my device is not connected. The same situation is with the version of Firmware v4_1_373, all other devices are connected, but the device with Wiznet W3100A chip is not connected.
Locally, I was able to solve the problem only return to the version of Firmware v3_60_453 on NI-3100 (NI-700).
Question: what has changed in the process of connecting to the AMX controller IP on Firmware versions above v3_60_453?
