Show/Hide Effect X Position not working in TP5?
I'm trying to have a popup page slide in from the right, but from 60 pixels in from the absolute screen right. I'm using a 1901, so my panel is 1920 pixels wide, which in TP4 would've meant that setting my show/hide X position on the popup to 1860 would've given me a nice slide in and out. In TP5 it seems like it's ignoring that number, no matter what I put. I've tried 1860, 1800, 1700, 1200, 0, and they all seem to give me the exact same effect: Slide from full screen right.
Is anyone else seeing this? Does this feature just not work in TP5? Or is there something else I'm likely doing wrong?
> send_command button.input.device,"'^PPN-MenuPopup'"
I have a MXT-1901 running firmware 1.4.8, TPDesign5 1.3.0 build 80. There's literally nothing to this project yet as I'm just spitballing a new UI. I've attached the workspace. On my touchpanel the hamburger button can be seen starting and ending off the right side of the screen, instead of coming from behind the vertical bar, which is where you'd think it would come from with the start/end position set at 1860.
http://www.amx.com/newsroom/videos.asp?Category=Development Tools&videoId=TPDesign5Part3#vidframe
