SVSI Control and Switching
George Krietsepis
Dear All,
I'm a little confused with SVSI devices control and switching. I have the below scenario :
A DGX controller with ASB audio switching card adjusts some areas volume level independently. One of these areas has an SVSI decoder which receives a streaming video from a managed network switch and also controls a local display from its serial port. There are also 3-4 sources connected to SVSI encoders.
What we'd like to do is to switch these sources to the display but also to control the area volume level. What kind of UI should we use in this area ?
Should we use only an N-Control panel for making the switching between the encoders and decoders ? Can this panel send commands to DGX for the volume control as well ?
If we use a Metreau Keypad ( Ethernet series ) - connected to DGX - can we make the SVSI switching ?
So as a global question :
Can an N-Control panel send commands to an AMX controller ?
Can an AMX panel ( keypad, modero, etc ) send commands to SVSI devices ( eg. video switching ) through an AMX master controller ? Should we use - for example - an SC-N8001 N-Controller to translate to SVSI commands?
George
George
API docs are here
http://www.amx.com/assets/manuals/SVSIN1000N2000Series.APICommandList.pdf
http://www.amx.com/assets/manuals/SVSIN300Series.APICommandList.pdf
Simon
Unsolicited Status
Enable
Send Status Address
I just found it.
Port 50005, UDP
