**ONSITE** Comcast/Xfinity New IR files Needed
the8thst
They have a new remote. I have 3 boxes and need to try to get them working before the weekend. None of my existing Comcast/Cisco/Motorola/SA Codes work.
I need AMX, RTI, or Pronto format. Thanks.
For this remote:
http://customer.comcast.com/help-and-support/cable-tv/xr2-xfinity-tv-remote/
For this remote:
It's just a text file but you can paste them into IREdit
Thanks.
I did end up getting it mostly working, but I have a fair amount of double hits and timing issues. Favorite channel (XCH) macros don't work reliably at all, so hopefully your codes can fix that.
Is this for the Comcast X1? I've searched briefly and read gnarly things. Have one incoming on a job and want to know if it's doable or if someone has pulled together a full IR file. I appreciate any experience/codes anyone can share.
FYI, you cannot currently turn the X1 off via remote (on still works though). It was working, but Comcast pushed out an update to the boxes which disabled it. You can disable the on/off LED, however.
Hey,
I've thrown everything I can at this. I've searched all over the web. I know that Universal successfully created a code set that works with their RCs but I can't get anything to work w/ AMX for this Pace STB. I tried capturing into the IRIS from the Comcast remote and the URC remote with their code file. There's no CCF file available yet. This is a major new platform for Comcast. I'm assuming AMX will get something in their library given that URC has shown its feasible. Not sure I can wait that long.
Alternatively, if anyone has a list of tips & tricks that've worked w/ Pace boxes in the past, please let me know.
Thanks so much - these work great. We were about to give up.
How'd you capture them? I've never hit a wall like this w/ IR.
Guys - if you've got 30 seconds to spare, can you click on over here
http://www.amx.com/inconcert/trednet.asp?page=vote
and select Comcast/Pace X1?
The IR file from the8thst is ok but still problematic. This X1 is a huge deal from Comcast. RTI, Logitech, URC, et al have created IR files but they've had to collaborate directly w/ Comcast. As far as I can tell this isn't a case of someone just using the IRIS.
So, I could use the help of the community to request AMX to call Comcast and get this thing figured out.
Thanks in advance. I've been sweating all month on this one...
