Dynamic Images...
itismyworld
This may be a stupid question...
When you add a dynamic image to a panel (like a CCTV MJPEG to TPControl); does the stream constantly update in the background or does it only update while the video window with the stream is active?
If it does constantly run; is there a way to kill the stream while not viewing?
Thanks all!
Thanks all!
Now then, when you have a URL such as a camera stream, it is essentially always "Refreshing".
The help file does not say what is actually happening in the background. If your URL is constantly refreshing, is the panel still getting hit with that data in the background? If you say it doesn't John than that's good.
I came across this because I am trying to get a FLIR Digimerge IP Camera video to multiple panels. It works great on the TPControl panel. However, it does not work at all on an older NXT-1200VG panel. In fact when I try to get the URL on that panel, it actually crashed the camera. Which made me wonder about what happens in the background when multiple panels try to stream the same URL direct from a cheapo IP camera.
TPC expands a number of covered protocols in video above and beyond what AMX panels (particularly the ancient ones) can do. So what you report is not a surprise. It is not likely the multiple connections, but if you think it is, stop connecting anything but the 1200 and see.
