Am I hosed - eBay purchase gone bad?? - Enova DVX2100
Hi all:
Been awhile since I've been here. Last week I bought an older Enova DVX2100HD to tinker with. The problem is the prior owner didn't clear out passwords before it was sent off to an eBay reseller. From what I can tell, it's in great condition, I'd love to use it, but can't get past the login and password in terminal. I read about "factory reset", but that seems to indicate you have to open a telnet session and I don't have a clue what the IP of the device might be.
As you can tell, I'm totally in the dark on this one.
Any help appreciated.
Classes start Monday and Facilities still doesn't work any faster than they did when you left....
Anyway, I used Wireshark to grab the IP Address, then connected to the web interface; stuck at login screen. I'm thinking this machine came out of an NSA conference room, considering that even the program port is locked down.
Any hope??....a jumper I can set, remove a battery for a fortnight, gamma rays?
Firmware reported from online tree:
NI Master: v3.53.453
NI-2100: v1.30.8
DVX-2100HD-SP v1.4.19
I cannot guarantee it will work, but it cannot hurt.
1 Unplug the device you need to investigate.
2 Plug a crossover cable from your PC to the device.
3 Start Wireshark on your PC and select the Ethernet interface.
4 Power up the hardware device you need to investigate.
5 Run Wireshark for 30-40 seconds. Stop the live capture.
6 Look at the list for IGMP protocol. The Device IP that is not your own should be listed under the "Source" heading.
