Kramer protocol 3000
Hi Guys,
i have a problem with kramer protocol 3000.
I get the feedback but impossible to have commands working.
Please advise!
Example of command:
send_string dvkramer,"'#AV 3>4',13"
Thank you!
Cristi
  • Try #VID instead of #AV
  • cristibadcristibad Posts: 69
    not working...
  • zack.boydzack.boyd Posts: 94
    I've never used decimals instead of hex. Not saying it doesn't work, but what happens if you use $0d instead of 13?
    Z
    solved! when using the command in terminal didn't work. assigning them to a button works perfect!
    does it work with #VID or #AV ?
    thanks.
  • @cristibad said:
    Hi Guys,
    Please advise!
    Example of command:
    Thank you!
    Cristi
    Syntax is good....
    There is no difference if using 13 (decimal) or $0d/$0D (hex) as carriage return, they all have the same value.
    As you say you get respone, also the baud rate must be ok.
    By the protocol manual, you can also use a simple terminal program for serial control, just typing the command and hit enter. Is this working? (of course you may have to use a USB-RS232 adapter if your PC/laptop has no serial port).
    If both NetLinx and terminal don't work, maybe the serial port of the Kramer unit has a problem on the input side.
