Controll an existing DM-MD16X16
Hello,
I have an Install i need to upgrade to an AMX Controll system with an existing DM-MD16X16 video Matrix.
Has someone controlled already some experience with controlling one of them ? i found no commands in the usermanual.
Thanks a lot.
Kind regards
  • JasonSJasonS Posts: 229
    It is entirely possible to control a DM Switch via Telnet, i think port 23 and 41794 both work. DM will report "offline" status unless you can find some deeper protocol info. It has been awhile since I did it on a regular basis, but reports from the field indicate these systems still work well. Don't remember where I came across the commands, i think they are on Crestron Labs forum. I even managed to get RS232 passthru to endpoints working, however it messes with Toolbox connections to the endpoint.
    The other thing a lot of people do is use a small Crestron master and write a small program to handle an RS232 or IP connection from the AMX master to control the DM.
  • MLaletasMLaletas Posts: 226
    Not true, or at least not documented widely, here is a snippet that I copied from another medium:
    Set AVUROUTE [inputSlot] [outputSlot] for A/V/USB, SetAVROUTE [I] [o] for A/V only, SETVIDEOROUTE, SETAUDIOROUTE.
    Notes
    1- This doesn't update the front panel status and isn't intended for normal operation
    2- The output SLOT number, not the output number, e.g. output 1 on a 8x8, 16x16 is 17 IIRC
    3- Input 0 can be used to route no input to an output
  • Thanks guys :wink: !
