Changing Border Styles
Clingpeach
Can someone point out how to do this. If there is a border already assigned to a button. In the properties section there are only 2 choice none or the border assigned. How do I get the full list thats available. Do I have to assign a new button??
Thats not what I want. I want to keep the existing button merely changing the border style
a) creating the panel in TPDesign3,
b) creating the panel in TPDesign4, or
c) changing the border style from code?
It also may be helpful to know the panel model and firmware version. Further make sure you use the latest versions of TPDesign.
If you mean TPDesign4, do the following:
1) mark the button you want to change the borders
2) in the button's GENERAL properties, set the BORDER NAME to NONE
3) go into the button's states and now you can select any border you like.
Hope this helps.
