Hardware/Software ideas and requests
 Spire_Jeff
Spire_Jeff
                    This came about in a different thread, but I think it deserves it's own thread. I apologize for not checking for an existing thread, but let's use this to reiterate some of our ideas and desires.
I'll start off with the two desires I posted in the other thread:
1. A new updated keypad. Preferably IP based with updated appearance (maybe even partner with Lutron and offer the colors that they offer??? )
2. A Wireless remote that is based on the 802.11b/g standard. Something that allows a person to channel surf without feeling like they are a NASA employee trying to land a space shuttle.
3. (not mine, but I'll post it anyway because I like it) On the fly palette changing. hmmm, maybe the ability to sort of morph between palettes? So that instead of moving from palette 1 to palette 2 instantly, the touchpanel slowly moves the color values up or down in steps of 1, 2, 5 or whatever until the RGB values meet the new palette? In a board room, this could be used to signal the people using the room that they have 5 minutes left till the next group needs the room or something without being overly distracting???
I'm sure I'll have others, but I look forward to seeing the ideas that everyone else has come up with.
 )2. A Wireless remote that is based on the 802.11b/g standard. Something that allows a person to channel surf without feeling like they are a NASA employee trying to land a space shuttle.
What do you mean by wireless remote - do you mean a wireless remote for channel serving only. I trying to clarify.
Thank you
Kenny A
I thought of a few residential applications myself, but the most usefull example I could think of was the commercial one (one I thought might apply to the masses
As for wireless remote, I kind of picture something like the MX-800 from Home Theater Master, but as a device on the netlinx processor connected via 802.11b/g. Think of it as a scaled down MVP-7500. Maybe like a DMS meets MVP sorta deal. It would be great if this remote could come in around the $500-$700 price range (Retail). It would be even better if the remote could be in the $300-$500 Price range. Or if they could do a one-way remote in the lower price range and a two-way remote in the upper price range. The other idealistic thought this brings to mind is that this technology could easily be applied to both keypads and handheld remotes (but, this is pure speculation
Over $11k/$12k MSRP for an XGA resolution panel (a necessity for TakeNote) is way too steep IMHO. I recently bought a 1280x1024 17" LCD display for $200. Of course this only displays what the $350 Dell / $500 MacMini sends to it and does not offer a touch interface, but the $10k+ price difference can be very hard to justify, and using a TPI/4 is not always a good solution.
2. Add a wired ethernet port to the MVP panels and/or their docking stations so they have a very reliable network connection when docked.
3. Like others mentioned before; a small simple handheld remote with real buttons, preferably using WiFi (G with WPA, etc.). Think of a something shaped like Tivo's. Allow for a customizable (printable) 'wrap' similar to the one HP sells for the iPod to provide the labels.
4. A successor for G3 web control (but we'll probably see that at Infocomm)
This panel could do without computer control (too small) and connections for USB keyboard and mouse are also not needed.
Also the panel housing itself could do with an upgrade, a more scratch free finish with a few color options...
-- [edit]
Oh, and perhaps a PoE ethernet port on the NI-series for applications where only the WAP needs to be connected to the NI. This could replace the ICSNET ports since they seem to be abandoned anyway...
I would like to second (or third) some of the previous suggestions:
1. I agree with Wilbert - add an Ethernet port to the MVPs and to the MVP docking stations so a hardwired connection can be used when possible for a more reliable connection.
2. Handheld Remote Control - something like an RTI or Home Theatre Master that works directly as a Netlinx device. Preferably WiFi and bi-directional but most anything along these lines would be a great enhancement to the product line.
Other ideas perhaps not covered here already but discussed elsewhere:
3. DMS Keypad replacement - a native Netlinx device with full level control in both directions (need to be able to combine DMS levels with other devices).
4. NI-700 - offer a version of the device with an ICSNet port either in addition to or instead of the Axlink port. I like the device (lots of memory, fastest processor of any Master) but the lack of an ICSNet port is limiting at least in my applications.
5. Single room A/V device controller similar to the old PMB-TCC (NI-700 was a good idea but I am referring to an ICSNet replacement for the TCC). The NXC-IRS4 gets you a long way there but the old TCC had IR outputs, IR input, a built-in VSS, and contact inputs. Stuff a serial port on it and a mini WiFi access point as well. Let's see how many goodies we can get into a small footprint device.
Reese
I would like to see them develop a wireless module shell that would acommodate any available control card. This would work out great for portable lecterns, and applications where running new cabling isnt cost
effective. If they can make a panel wireless, why not a module?
Personally, I am still undecided if I like all the new ethernet connectivity in the control systems. I have yet to see an application where everything works perfectly 100% of the time. The networks are getting so over-populated, especially in the wireless area. Youd can integrate the best control system around, and it is at the mercy of the customers LAN. There is a part of me that still likes the proprietary communication for control panels. I do realize the benefits of the ethernet capabilities, but with every advancement, there also is a drawback.
Just like many others, I would like to see some physical changes to the MVP series panels. I also agree the pricing for the larger panels is ridiculously expensive.
Thanks.
1- I would like a controller with the simple stereo volume controller built in, 1 box.
2- The HTML web pages to auto-sync with the touch panel without the need to write the code to do so, this could be selectable option that could be turned on/off depending on how the programmer wants the panels to interact.
A cheaper Modero panel to replace the G3 that exist now.
A small LCD panel on the front of netlinx masters that shows the IP address...and maybe some other basic config information. The only easy way around is to put a G4 panel on the network, set it to "auto", and let it connect to the master on its own to find the address. Otherwise its off to the rack with an rs232 cable to run diagnostics. Since its getting harder and harder to find laptops with real serial ports this would be a great bonus.
An AMX branded USB keyboard and mouse that match the modero panels.
I would like to see more ethernet ports or a built in hub and or access point on the NI controlers.Why have loads of boxes for one system.
No 9 way d-types on the NI's.
A more robust wall docking station.
And a 10" modero panel not wide screen for lecturns.
I would like to see a new style connector for the intial setup of the controller. With more and more laptop companies dropping all but the latest port connectors, it is hard to find a laptop that has DB9(and the USB- DB9 don't always work) Perhaps a USB style.
Firmware update program, like the Web update Program.
Which looks at a system tree and compares the firmware dates and uploads the newest one.
Hi Cameron; A few months back I posted a poll with this as the question. I too would really like to see this feature.
If you open a NI-700, on the back there are 2 solder places which look like there may fit relais, but...
- an updated version of NetLinx Diagnostics (G4 support, etc)
- a software tool "Workspace Loader" -> load a workspace into the tool, check the comm and device settings and download all the stuff
Both to have small tools to give to the not-so-experienced customers, for simple diagnostics and to have a way to download all the necessary files without that big Studio environment.
BTW - what about a simple integrated IR file viewer in Studio? So it would not be necessary to launch the full IREdit just to have a look into the code list of the IR file....?!
Just my two cents.
I thought Barco? either had or was working such a system some years back, looks like it didn't work or catch on.
Tom
Good idea guys and now girls.
Add USB Programming Port to NI Controller. Hard to find COM port in a Laptop PC nowaday.
I'd say skip the USB and just use the Ethernet port that's already there, but then you need an easy means to set the Ethernet parameters.
Agreed. Able to use arp to set the IP address of the controller may be a good idea.
Need to connect a cable to a DB9 control port? Forget the hassles of parts, pins, and soldering--get an STS, lock the wires down to the built-in screw terminals, and plug it in.
They work quite well.
Screw-terminals are nice but, quite expensive, 9-subs are Cheap.
<a href="http://www.amx.com/product-details.asp?pid=295&lin=84&pf=1|13">http://www.amx.com/product-details.asp?pid=295&lin=84&pf=1|13</a>
The MVP Panels are bit plastic looking take a look at cr*****s wireless panels
they are all made of 2 cases, eg a back part and a front part.Not like the MVP Panels which have push on a front panel.Which sometimes comes off.
And the plastic cover paint does not last after a few scratches.
Sorry if i am ripping the panels.
But please improve the case for these panels.
