Anyone using Java/Duet?
maxifox
Can someone share her/his opinion on using Duet - how it is going? Are there some obstacles on the way still? Did you get clear advantages from using Java?
After getting Duet are you going from now on stick with Java and slowly give up on Netlinx Studio with its "regular" Netlinx?
Any news on can we program mainline in Java or not yet?
I would be appreciate any opinion and experience on Java with AMX...
P.S. I know about similar thread in Duet/Cafe section but looks only a few replies are there and thread is slightly outdated - or not so many are really using Duet??
I'm not >terribly< bothered by this, as the biggest benefit I was expecting (told?) was the ability to just write some processing code in Java that would run faster/better/with more options than NetLinx code. So far, AMX has been cranking out device templates that I just don't give a damn about, and hasn't done squat with regards to just a "code module" template.
