IM Netlinx?
TurnipTruck
Greetings,
Does anyone know of a way to send an "Instant Message" to a Netlinx system? My cell phone (Nextel) has an AOL IM interface and I'm sure most others do.
I am trying to acheive a more dynamic WAN control of my system. Currently I use the I!Equipment Monitor In checking a mailbox quite frequently. This method can be slow to respond and is quite a bit of effort for the occasional remote command. An IM type method seems to be the ideal method.
Any ideas? Thank you.
Concerning AOL, protocol is closed and pretty complicated to implement in a NetLinx System. Do you have a way to run a Jabber client in your cellphone ? Well better as it's an open System
Vince
One thing interesting also with Jabber is Gateway concept. With a single account on Jabber you can be in same time connected at all other IM networks
Vinc
Well.. MSN, AIM and Yahoo Messengers may very well be closed sources but there is an open source IM client that works with all of them.
http://gaim.sourceforge.net/
which leads me to believe that they all have some kind of public API available for programmers to work with them. Maybe someone out there can shed some light on where we can obtain something like that?
Vinc
This was one of the things I was hoping Duet would help with, but the Java version in the Duet firmware has the HTTPS calls taken out.
Chip, is this true?
Did you check with Tech Support concerning HTTPS?
