AMX vs c******n
bano
I am presenting an AMX proposal to a client who is also considering using c*****n for his residence. I am attempting to formulate valid, compelling arguments to strengthen my (and AMX's) position and convince my client to choose AMX over c*****n without resorting to disparagement. Any input or suggestions will be greatly appreciated. Thank you.
Being a consultant I see both companies equipment often. I tend to use AMX whenever possible. The main reason I don't always agree with the aggresive sale people and their tactics from the "C" people. The AMX modero panels are way ahead in terms of graphics abilities. AMX also has an easier way to setup and control the access for multi-users and access to different levels of usage. I also believe that the AMX power supply is more robust than "C", I know of a client that has several AMX units and "C" units and after a power failure ALL the AMX came back online, however I can't say the same for the "C" units. Multi units failed. Just a few things that I have noticed.
As I understand it there are many more C*******n dealers while AMX offers a limited and more select distribution. AMX does one thing really well, CONTROL! AMX does not push lighting, A/V etc., but recommends that the AMX dealer work with its InConcert partners that are the best at what they build.
Other advantages include G4 graphics, Dynamic Images, MPEG streaming, Computer Control, Java/Duet, secure shell security, NetLinx operating system is separate from the running program allowing firmware updates without the need to recompile the code. Also AMX has a track record for supporting old hardware (Axcess) when new technology is introduced.
