Dealer Tool Kit - suggestions?
maxifox
Could anyone please share his view on what it would be? I guess anyone found in a hard way that having this or that (including software) could save...
Trying to have something like the old one PM-DTK Dealer Tool Kit (crimp tool, chip puller, DMS test panel, wire tester, PM-PLCNM, ESD kit).
Thanks in advance.
Thanks in advance.
- various test cables (normal/crossover) RS232 & CAT5
- various known good device specific test cables (VISCA, HIROSE, etc)
- RJ45 crimper and connectors
- wire cutter/stripper
- RJ45 barrel-thru connector (for extension if needed)
- DB9, DB15, DB25 connectors
- various gender changers
- tweekers
- mini flashlight
- VGA cables and adapters
- VHS tape
- audio CD
- test DVD
- audio cassette tape
- mini-disc cartidge
- 35mm test slide
- spare 12v power supply
- soldering tools
- short lengths of various wire (pair, 5-cond, CAT5, etc)
I realize that this sounds like a lot, but when you are onsite working with a system, and you have what you need, it is worth its weight in gold!
Actually, this all fits in a small case with my laptop.
