IR files for Rotel
Denis
Hi everybody
I'm looking for IR file for Rotel RCC1055 - RDV1060 - RSP1068 - RT1080
All units are in my demo room. I looked for an Iris but it is very expensive in Canada.
Somebody can help me ?
Kevin D.
Tanks guys
RS232 are present on all models, but since it is my first experience with AMX (I'm working on my demo room presently) i want to explore all ways. I programmed my Vidikron in RS232 and I use IR codes for audio component, for the moment. I'm not familar with RS232 command and i would like to experience it with one unit before apply to all system.
This works with RS-232. RS-232 is a way better way to control the Rotel; using RS-232, you can get feedback with 2-way panels.
Tanks
I will follow your advices
Tanks Jeffaco
I looked Rotel module, but tey are not for my models, I suppose as each model has the specific module, and I have to tell you as I have to learn to work with module.
In the other time, after installation of all system, ( RS232 command for Vidikron projector Ir for Rotel units) all work well exept my Rotel DVD.
I followed Rotel protocol and command listing, but it donsen't work. The RX TX led on master blink ( RX some time only). My serial cable seem good...
