Problem with No-IP
[Deleted User]
Hi all,
I have a residential installation which is using NI-3000 without fixed IP but would like to make use of free service provided online such as No-IP.com. However so far I have not been able to configure it to work seemlessly. I was wondering if any of the senior here has make use of dynamic dns to successfully make accessing the NI-masters remotely possible. I would really appreciate if anyone of you can provide me with some insights, Thank you!
regards,
Zhihao
regards,
Zhihao
AFAIK someone in the forum also has written a DynDns module, so you don't need a router capable for that service.
http://www.amx.com/ip.asp
I use No-IP for my home system so I can monitor it while at work or out of town. Works fine for my two systems. My reply is probably not what you want to hear!
Tell us what is not working "seamlessly" and maybe someone can help.
Tom
I too use no-ip for my systems at home. That gets me into the home network, but still requires port-forwarding in the router to direct port 1319 traffic directly to the NetLinx master. Once the port forwarding (or "Virtual Server") setup was done, everything runs smoothly.
Previous suggestions for DynDNS module and Equipment Monitor are also valid. Equipment Monitor also includes email notification feature--very cool. For true logging and reporting info on your system (or your client's system), you'll need to move to the Asset Manager or Meeting Manager.
