Home AMX Resource Management Suite Software
DGX Monitor?
Does AMX have a pre-written DGX monitor for RMS? Or is this yet another area where AMX dropped the ball on the DGX line?
  • champchamp Posts: 261
    Here is a module I wrote that talks to a serial port on a DGX and gathers all of the commands.
    You need a spare serial port though.
    This relies on AMX not changing the format of commands and responses to a DGX serial port, so far they haven't done so.
    To compile it you'll need the RMS SDK on your PC, I can't post that or I'd get a big slap on the wrist.
    The program reads the status of a DGX using a serial port connected to the serial port on the DGX, and reports the status to RMSE.
    The current revision reports the following:
    - Power supply status
    - Number of input and output boards
    - type of input and output board
    - Link status of DXLink connections on boards
    - fan speed (main fan only)
    Maintenance alerts are triggered for the following
    - unplugging an input or output board
    - unplugging a DXLink input or output
    - unplugging a power supply
    - threshold power supply
    Things that aren't currently reported:
    - temperature
    - internal boards
    - internal fans
    - video connections other than DXLink (not reported so can't do anything about it)
  • mstocummstocum Posts: 120
    champ wrote: »
    - temperature
    - internal boards
    - internal fans
    Yeah, this is my problem with the DGX line right now. Diagnostic commands need to be sent over the serial port, with "port 1 support coming soon". No status reporting on internal cards. No audio breakaway. Etc. Etc. It wouldn't be so bad if the DVX line wasn't so much better. I have 10 year old Extron gear that does more than the DGX switchers do.
    ETA: Thanks for the code though! Very impressive, especially given the limitations of the hardware.
  • This posted DGX RMS monitor works with the DGX 100?
  • AntAnt Posts: 54
    Any chance you have this module still?
